Well, I started my ballast install this weekend. I got the electrical run and mounted the switches in the dash. I then decided it was time to put in my first thru hull.
I drilled, chamfered, put the sealant on the fitting and tightened it up. This was pretty late Friday night so I decided to call it a night and left it to let the sealant cure. This morning I headed out to install the ball valve. I started threading it on and the thru hull spun with it. That pissed me off so after swearing for about 20 minutes I took the thru hull fitting back off, cleaned it up and reinstalled it. This time I tightened on the ball valve before tightening the thru hull. But when tightening the thru hull, I had a buddy try to hold it in place while I tightened it up. I tightened until he could no longer hold it. It did eventually spin a little.
The question I have, how tight is good? I was afraid to overtighten it and hurt the fiberglass. Second, it is cold here, I used 3m 4000 Uv fast cure, I am heating my shop but its probably only about 40 degrees. Will I have curing problems?
