My ballast install plan has changed and I'm now going to use tsunami 1200 pumps. My questions (which will be one of many) is that where is the best place to put the checkvalves? Close to the pumps or close to the bags? High or keep them low? I will be using one thru hull for vent and outlet, which are mounted forward under the windshield so I will be using 3 c/v per sack.
Check valve placement
Vent line c/v: anywhere between the sac and the T if you plan to have the vent and drain share a thru-hull.
Drain line c/v: serves no real purpose. Especially if the line is either running forward or across the boat.
Fill line c/v: I typically do not use a c/v here when using aerators, especially in the deeper hulled boats like the Ve or RZ series. It can cause the pump to vapor lock. When the boat is pulled from the water, all the water on the inlet side of the c/v drain out, leaving water on the outlet (sac) side of the c/v. When the boat is launched again, air is trapped in the line between the thru-hull and c/v. The water on the other side of the c/v adds head pressure. This can be enough weight to prevent the c/v from opening and purging that trapped air from the pump. If that air does not purge, the pump may not prime. Having the pump as low in the bilge as possible will increase the water pressure, cause its below the water line, thus counter acting the headpressure of the trapped air. So, if passive draining through the fill line is the issue, an anti-siphon valve works better.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostVent line c/v: anywhere between the sac and the T if you plan to have the vent and drain share a thru-hull.
You definitely will encounter passive draining in bags in the rear of the boat. May not be a significant amount, and may be limited to certain situations, but it will occur without a device in place to prevent it.
A vented loop is overkill for the rear bags, just use a check valve, and install it at the high point in the rear hose. In that configuration we never encounter air-locking of the pump. Vapor lock is when a fluid boils in a closed system creating, appropriately enough vapor, which almost all pumps are incapable of clearing. This typically happens in the fuel system, and could never really occur in a ballast system.WakeMAKERS.com | WakePROPS.com
Now back to the topic of vapor-lock. The air trapped in the lines is the same air we breath. Its made up of mainly Nitrogen, Oxygen, Argon, Carbon dioxide as well as others. These are all called gasses.
Vapor: a substance in the gaseous state as distinguished from the liquid or solid state
So, I dont think its too much of a stretch to say that air trapped in the body of a pump is "Vapor-Lock", even though it didnt boil first. This is a real problem in ballast system. Ive seen it and addressed it in OEM systems using check-valves in the fill lines. Here is an example: Tige used to place the ballast manifold intake in the transom. Upon launching, air would be trapped in the ballast manifold. The orientation and weight of the flapper, with water trapped on top, would prevent the air from purging out of the manifold through the pumps. This prevented the pumps from priming. The short term fix was to goose it in reverse. This forced the water through the pumps purging the air. Long term was to relocate/reorient the c/v. So call it what you want, its real.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
In aerator systems I always put check valves on everything. The goal is to keep air out. I like having aerators installed through the rear transom. That way if they do get air in them, you can put the boat in reverse for a quick second and prime them. The tsunami 1200 suck! I would stay away, their thread is strange and hard to adapt. I would use the rule 1100. Easier to adapt and the loss of 100gph won't matter. Especially since the 1-1/4 tsunami 1200 most people size down to say and 1".Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
Originally posted by duffymahoney View PostIn aerator systems I always put check valves on everything. The goal is to keep air out. I like having aerators installed through the rear transom. That way if they do get air in them, you can put the boat in reverse for a quick second and prime them. The tsunami 1200 suck! I would stay away, their thread is strange and hard to adapt. I would use the rule 1100. Easier to adapt and the loss of 100gph won't matter. Especially since the 1-1/4 tsunami 1200 most people size down to say and 1".
The Rule 1100 is actually faster then the T1200, so its a gain, not a loss
and the original T1200 has a 1.125" straight thread inlet, not 1.25"Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Wow when did the t1200 change to 1" NPT? That's awesome, the old thread was terrible for adapting. If anyone has aerator questions I have installed- designed a few and have learned a lot through trial and error.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
Originally posted by duffymahoney View PostWow when did the t1200 change to 1" NPT? That's awesome, the old thread was terrible for adapting. If anyone has aerator questions I have installed- designed a few and have learned a lot through trial and error.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
So far rule pumps have been great. I am using 2- 1100 to fill my bow and 2- to drain my bow sacs and 2 rule 3800's to fill my rears and 2 -3800's to drain the rear sacs.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
I might install 2-1100's as crossover pumps between my custom sacs to get my transfer time down to below 4 minutes. I switch sides a lot while surfing. Say 4-5 times a day.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
