Does anyone no what kind of pressure a jabsco impellar pump produces? I would like to install a Y in the output line and attach a garden hose connection so I can pump water to shore for things like a slip n slid. Any ideas?
Jabsco pump pressure
Will this be a pump thats already installed in the boat as a ballast pump? If you are buying a pump just for this purpose, then skip the ignition-protected Ballast Puppy and go with a cheaper non ignition protected fluid transfer pump.
I would stay with an impeller style pump though. They loose less pressure p/ft of hose as compared to a live-well style. Pumping up on shore for a slide could be a bit of distance.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostWill this be a pump thats already installed in the boat as a ballast pump? If you are buying a pump just for this purpose, then skip the ignition-protected Ballast Puppy and go with a cheaper non ignition protected fluid transfer pump.
Originally posted by kspwski View PostThe manual for a ballast puppy includes a head-flow table that includes pressure. Link to manual
I should of thought to check the manual
Originally posted by adamsjstt View PostI was thinking about using a existing pump that was used for ballast just add a Y and shutoff valve, since the pump would already be installed. Maybe I will look at a dedicated pump just for pumping water to shore I was just tryn to make it simply and help justify the cost of jabsco pumps.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
