Originally posted by Ewok
View Post
RZ2 basic ballast to Surf plus
Originally posted by adamsjstt View PostIs it necessary to run the thru hulls above the rub rail? Or will that be to low?I am looking at the same location as WAboating's but about 1 inch below the rub rail
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
On my old 24V and my current boat with big custom sacks, the level of the top of the sack is still barely below the level of the overflow, so self draining is a trivial problem. I see about a gallon come out during an entire surf session (about 8 pounds). It is a small trickle.
It seems only necessary if your boat is especially shallow, or the sack is so tall that it is above the level of the overflow when the boat is in surf mode. Even keeping in mind the lean, and the rise.
I would still put the overflow in the front of the storage locker, but below the rubrail. It just looks so much better, IMHO.
This is a full custom sac (almost the same specs as the enzo sac, but it was made before they created the enzo sac). The overflow is in the rear compartment, towards the front. No water is coming out.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by talltigeguy View PostIt seems only necessary if your boat is especially shallow, or the sack is so tall that it is above the level of the overflow when the boat is in surf mode.
Originally posted by talltigeguy View PostI am going to go out on a limb here and state that I think this problem is not nearly as big as it is being made out to be. Now I am sure I am going to take a quick beating...
On an RZ2 with sacks going to the top of the rear lockers and the boat heeled over so water kisses the rub rail when at surf speed, you will auto-drain unless you take measures to prevent it (e.g., drain AND vent to opposite sides; check valves; run lines to bow, etc).
Our sack will lose a quarter of its water over 30 minutes or so.
Always put valves inline or vent to the other side. A sac can easily lose a 1/3 or 1/4th of it's total weight while surfing. Just easy to do. I just vent and drain to the opposite side. Works every time.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
Originally posted by duffymahoney View PostAlways put valves inline or vent to the other side. A sac can easily lose a 1/3 or 1/4th of it's total weight while surfing. Just easy to do. I just vent and drain to the opposite side. Works every time.
Also use check valves, keeping air out of the sac is super important. I can tell a difference in the wave if I don't "burp" the sac while filling. The check valves help, but I always seem to get air in them.
If you have an aerator system then check valves on fill, vent and drain lines. If you have impellar, then just check on vent lines. I don't know a lot about impellars. I installed a system on my first v-drive but I ripped it out and installed aerators. I hate the loud noise and battery drain of the large pumps.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by duffymahoney View PostAlso use check valves, keeping air out of the sac is super important. I can tell a difference in the wave if I don't "burp" the sac while filling. The check valves help, but I always seem to get air in them.
I don't have any valves anywhere in my ultra-ballast system (didn't want the valve restriction slowing my fill and drain times) so I gave a lot of thought to letting gravity and buoyancy do things naturally.
I have the vents on the highest point, but it still can trap air. I have designed 4 systems now and I continue to learn a little everytime. I use flapper style 1 ways and I get no noticeable flow loss. I still have to burb, my sac fills the space so well and the pumps are so fast that it can trap air even with the vents at the highest point.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
