Admittedly, electrical is not my strong suit. I'm trying to figure out the best way to make a Ballast Puppy run in the opposite direction of the factory setting. I have already flipped the pump heads in order to make them work better with my plumbing plan but, I still need one to run the opposite direction of the other. Can I just switch the wires at the pump? Change the connections at the back of the switch? Install the switch upside-down and then just turn the switch face upside-down, making the switch, for all intensive purposes, run backwards?
Ballast Puppy switch reversing
Originally posted by NICKYPOO View PostAdmittedly, electrical is not my strong suit. I'm trying to figure out the best way to make a Ballast Puppy run in the opposite direction of the factory setting. I have already flipped the pump heads in order to make them work better with my plumbing plan but, I still need one to run the opposite direction of the other. Can I just switch the wires at the pump? Change the connections at the back of the switch? Install the switch upside-down and then just turn the switch face upside-down, making the switch, for all intensive purposes, run backwards?So this monkey walks into a bar...
If they dont flow in the desired direction after rotating the pump head, swap terminals 3 and 6 on the switch that go to the pump (ok, the actual numbers depend on which schematic you used).Attached FilesMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Thanks Mike.
While we are talking switches. Can the outer mounting plate be removed? I'd like to remove it and mount the switch in the factory switch bank. I have two open ACC switches that I would like to swap out with these? Just can't quite tell if they mount up the same.
Along those same lines, is the power running to the existing switches going to be OK for the new switches and pumps?You'll get your chance, smart guy.
Along those same lines, is the power running to the existing switches going to be OK for the new switches and pumps?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Nope. Batts are in the observer storage. It's a bitch getting power over there. That is unless I go all the way around the bow. Then its its just long.
I'll have to get back in there tonight to figure it all out. Should I be able to use the breakers for the existing switches?You'll get your chance, smart guy.
So ya, switches are piggy-backed. Breakers are 20 amp. So, I'll run new power over to the batts. New power to breaker, breaker to switch, switch to pump. Correct?
Can the new grounds be run to the ground block under the dash or do they need to run back to the batts as well?You'll get your chance, smart guy.
Originally posted by NICKYPOO View PostNope. Batts are in the observer storage. It's a bitch getting power over there. That is unless I go all the way around the bow. Then its its just long.
Originally posted by NICKYPOO View PostSo ya, switches are piggy-backed. Breakers are 20 amp. So, I'll run new power over to the batts. New power to breaker, breaker to switch, switch to pump. Correct?
Can the new grounds be run to the ground block under the dash or do they need to run back to the batts as well?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I've done the do to those holes before. It sucks. About a foot aft of those two holes, there is a small (6") hole through a bulkhead between the stringers. I call it the tunnel. With the amount of crap stuffed into the two holes in the floor, its impossible to manipulate the coat hanger from one to the other. The only way to make it happen is to run one hanger from the starboard hole through the tunnel and one from the port hole through the tunnel. I have to reach back up the through the engine bay, up under the floor to reach the tunnel about two feet fore of the engine bay. Thank god I have long arms. I went through this when I did the new stereo. It seems like it should be sooo easy. It is however the most PITA 18" inches on the planet. I'm doing a new steering cable at the same time so, I will have that as a pull through this time. I'm actually contemplating installing a deck plate in the floor, between the holes just to be done with. Just not sure I want to live with it once I'm done.You'll get your chance, smart guy.
Originally posted by NICKYPOO View PostIt is however the most PITA 18" inches on the planet. .Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostI thought John Holmes had that title
Switches are done! Just need to loom the run to the pumps. I managed to buy the wrong size loom.I'll have to pick some up tomorrow. No biggy. Checked pumps. All is good. Still need to straighten out flow direction but that can be altered at the pump connection.
Thanks for the help TOs!
Next up, plumbing. After that, new fuel tank.Attached FilesYou'll get your chance, smart guy.
Looking good so farAre you gonna get those sacs in the weekend?
