Looking for some thoughts on changing my ballast set up around. Here is what I have currently:
2005 24v
Typical DIY aerator pump ballast set up with 4 fill pumps and 4 drain pumps
dual 550s in the rear
dual 350s in the front compartments (dash compartments)
I need to fill an additional 440 in the front walk way to really shape the wake propperly.
I know the rule of thumb is 50/50 or 60/40, but placement of the front weight would have to play a big factor. I am sure there is some math equation out there that would figure this but I have been out of school far too long to try and figure it out, plus practical experience is always better.
Here are my thoughts, I would like to ditch the 440 in the walk way to get that area back usable and was thinking of these two options:
1. move the 350s forward under the front seats which would move the weight center forward and hopefully eliminate the need for the extra sac, however I don't see being able to fill them 100% in that area
2. Go to a single bow sac which I know won't get me its full 650lb but would move the weight still further forward.
3. I guess there is a third option, run less weight in the rear
Anyone play around with doing this? I like the idea of the single bow sac as I don't use those storage areas anyway (except for may anchor which I use maybe once a year). Thanks in advance!
2005 24v
