i just bought on 08 22ve with stock ballast. i have a set of v-drive sacs that i would like to plumb in the rear lockers. is it possible to use the stock pumps and t in the lines? im not too worried about fill and dump time. just need a little more weight.
need more weight
Check with Chpthrill - he is the ballast master and could direct you with the correct fittings/advice. Assume you have the hard tanks behind that awful battery box design - well worth the investment to remove and add one big bag.
See attach link as a reference point.
http://www.tigeowners.com/forum/show...allast+install
congratulations on the new purchase - that is a beautiful boat. Would love to see more pictures. I have the stock ballast on the same boat.
Are you looking at a surf set-up? I surf with one of the rear stock tanks plus a manually filled W705
http://www.wakemakers.com/fly-high-rear-seat-sac.html
on the same side. It is reasonable, but I am looking for much more weight.
Majestic is a good guy to talk to about how to properly weight your boat for surfing.
If you are talking about wakeboarding ???
Originally posted by tnvolgrad View PostCheck with Chpthrill - he is the ballast master and could direct you with the correct fittings/advice. Assume you have the hard tanks behind that awful battery box design - well worth the investment to remove and add one big bag.
Originally posted by lancehon View Posti just bought on 08 22ve with stock ballast. i have a set of v-drive sacs that i would like to plumb in the rear lockers. is it possible to use the stock pumps and t in the lines? im not too worried about fill and dump time. just need a little more weight.
Now, plumbing it in is tough, because the sac and tank are on the same plane. You can piggyback the system and have the sac fill using the vent line off the tank, but the sac will not drain without its own drain pump. This can be tied into the existing drain pumps electrical and plumbing easily, but is just a little added cost.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by majestic View PostMls I still think if you move the batteries forward and put a custom sac like the one I have you will be happy. You will get 250 pounds more than I have and I think mine's enough now. Just my
Anyone have any experience moving the Taps pump?
lancehon, you can do the same
Originally posted by lancehon View Postthanks for the info chp. I'll probably get a couple more pumps and piggyback the fill, and start saving for different sacs. if
I take the tanks out and move the batteries and taps will the enzo sacs fit?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by mls6722 View Posttotally agree - did you get the customs from Chp? I wonder if I can swap out the fill pumps which I believe are 800's for 1200's and piggyback the fill. Then just add 2 drain pumps?
On Jbort's 22Ve, we left the original pumps intact and added in a couple of new 1100 gph fill and drain pumps to supplement. It fills the custom sac in about 6 minutes.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
lancehon, The invite is out to you too if you ever in the Seattle area and want to surf.
Originally posted by majestic View PostI did get my Sacs from Chp and I would reccomend you doing the same. You know you already have the invite to come on my boat and you will see what the 1K custom is like. I am very happy with mine and they are stuffed on the goofy side. If you decide to remove the tanks I will happily take them off you hands and that will be my winter project. I would simply add another fill and drain pump rather than piggy backing them.
