Pump install
    Pump install
    Rear seat is out and I am trying to decide on where to put the pumps and thru hulls in my 2006 24V.
    1. The height of a rule pump with a ball shut off valve, and the thru hull is approx 11" to the top of the pump, and around 9" to the top of the outlet hose on the pump. It looks like it would be under the water line, but I was wondering if anyone has first hand knowledge,... or do I have to use a 90 elbow?
    2. Is it absolutely crucial to make sure pump is above the 90 elbow wich is attached to through hull? In some pics I have looked at it seems the pumps are just resting on the bottom of the floor.
    Thanks
    Life is good...
    Happy Wife Happy Life
