Custom ballast system tomorrow !
    Picking up my ballast order from the parcel service place tomorrow.
    Kid in a candy store.
    Life is good...
    Happy Wife Happy Life
    I finished my install last weekend and was able to ride it this weekend, "Dan and Christy" should have some pictures to post! What all did you get? Pictures!!
      Everything!
      5 sacs total
      8 pumps
      pile of fittings
      A mile of hose
      What I am plannning is the normal for the 2 rear 750's,
      1 pump to fill an intergrated bow and an extra surf sac that I can use under the bow insert cushion when needed. I will have those two bags work off a rule pump to fill via a manifold with 2 shut offs. The manifold I'm thinking will go just inside the access door on the driver consol area. and 3 pumps to empty, one for each leg of the ont. sac and a second for the surf sac. I have picked up a SS quick disconnect for that second bow sac so I can keep things relatively clean.
      My neighbor is going to lazer cut a custom aluminum switch plate which I will put just ahead of the shifter somewhere. I really dont want to work this week but go to the lake and install instal install !!
      I will make sure I take some pic's along the way !
      Life is good...
