So I filled up my ballast on Friday to take my first surf run with Chpthril's custom sac and just happened to check on my front sac. To my great surprise, there was about three inches of water in the compartment in front of the helm!!!
I found that water only entered the compartment when the pump was running so I just went and had fun anyway. Afterward when I took a closer look I found that although the pumps were filling the front bag (I have the 400 lb horseshoe sac that comes with the surf option), water was also streaming through the seam in the plastic that encases the pump. What does this mean? Is it just a crack in the plastic or is there a larger problem inside the pump. Does anyone know if this type of thing is coved under any warranty? It is a white fill pump on the starboard side of the bow that you can reach from the helm storage compartment.
Your thoughts? I was thinking of coating this seam in the plastic with cylicone caulk and seign if it holds.
