get that on the net?
Duffy's 2005 24v wakesurfing mod thread.
Got the big fill and big drain pumps plumbed and installed. The 1.5 inch hose is tough to deal with and drilling 4-1-1/2 holes in the boat is scary scary stuffMounted the fill pumps to bottom of the hull on their own plastic boards. The plastic boards are then liquid nailed to the hull.
Aerators or these pumps don't lock water in the sac when off like impellers. So I vent and drain to the opposite or high side. Basically the empty pump for the starboard sac empties out the port thru hull. Simple fix to keeping water in the bag.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
Yep that is one of the drain pumps, I will post lots of pictures later. Hopefully fill times will be around 5+ minutes and drain will be around 4.5 or so. The fill pumps are below water line next to the v-drive.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
