Ok got my 2nd home made wakesurf rack done. Had to drill the evolution tower, which wasn't easy. Again cut the middle fork out, had my buddy grind the forks so that 1/2 pvc fit then covered in dakine 18" pads. Works perfectly!
Duffy's 2005 24v wakesurfing mod thread.
Originally posted by rushin View Postduffy- What check valve's did you use for the front?Originally posted by duffymahoney View PostI used the wakemakers.com ones. It looks like the kind I used are out of stock or they aren't gonna carry anymore.
They look like this.
http://www.wakemakers.com/fly-high-p...w753-html.htmlMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Dan and Christy View PostHey Duffy, was the tower leg solid when you drilled through it? I have the same tower and am intrigued.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
Originally posted by chpthril View PostIve about a dozen of those here that are defective. Had to swap them out of two installs cause they would not seal off. This caused an air leak in the system so the pumps wouldn't prime.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
any updates on the wave? I still haven't seen your waves in all their glory. Cmon' I need some wave porn. I'm off the water for 2 days this weekend workin' and outta my mind. Freinds are text' me like crazy.. like wtf r u?
Between work i'm watchin lotsa' youtube wakesurf' vids. You need to post up and show those MC kooks what a real wave looks like..a man's waveLast edited by MooseX; 08-14-2011, 07:10 PM.my midlife crisis started at puberty and I plan on enjoying it all the way to the end..
