Q#1 When a manifold is made to run 2 Johnson reversible pumps, if the intake is off set closer to one outlet more than the other, is it going to make a big differences?
Q#2 I was planning to take power to the ballast switches with a 8ga power wire, then a 12ga direct to pumps. Will this work? Do I have to use relays?? With the reversible pumps I have no idea how or if it can be done?
Heres some info from the pump manual
Wiring dimensions
(based on 3% voltage drop)
Wire size Max wire
lenght* in m
_________________12V___ 24V
2,5 mm² # 14 AWG 2,7.....11
4 mm² # 12 AWG...4,4.....17,6
6 mm² # 10 AWG...6,6.....26,3
10 mm² # 6 AWG....11
16 mm² # 4 AWG....17,6
25 mm² # 2 AWG....27,4
*The wire length is the total distance from
the battery to the pump and back to the
battery. It is recommended to use a relay to
shorten the main leaders.
Q#3 I think I know the answer but on the Johnson reversable pumps there is a grower, black wire and a red. Could a single pole on-off-on switch work or does it have to be a double pole??
Q#4 When using a 2 pump Tsunami system do the bags passivily fill even thought the switch is off?
Thanks,
Wiring dimensions
Wire size Max wire
lenght* in m
Thanks,
