Hi Guys and Gals,
Here is a plan for rear ballast that I am thinking of doing. I will be using the Johnson Ultra Ballast Reversible Pumps.
The problem is my in-decision
on:
#1 where to have the thru-hull connectors,
#2 where should I mount the pumps. (I will need 3 of these pumps for 3 fat sacs).
#3 I have seen some installs with the thru hull fitting in the transom. Although you have to watch your speed when filling it looks like it would be easy to install the thru-hulls there. ??
#4 Can I run 2 pumps off of 1 thru-hull?
Here are some pics of the engine area. All help is appreciated,
1.
2.
3.
4.
1.
2.
3.
4.
