Why could you not use one ballast puppy or johnson pump and hook your switches to a sprinkler type solenoid valve on a manifold to fill the bags? Is this already being done and I just missed it. Seems a lot less expensive than multiple pumps for multiple bags.
thinking out of the box here
Originally posted by laserfish View PostWhy could you not use one ballast puppy or johnson pump and hook your switches to a sprinkler type solenoid valve on a manifold to fill the bags? Is this already being done and I just missed it. Seems a lot less expensive than multiple pumps for multiple bags.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Being a plumber I've thought about the solenoid valves on a manifold of 3 or more pumps with large 11/4 flexible pvc feeding bags ,switch controls solenoid instead of pump ,2 tsunamis sucking on each sac manifolded into 11/4 pipe (flexible pvc tubing with fullport glue ftg ) still just a pipe dream though
Originally posted by laserfish View PostWould you do them through the bottom or through the transom like Dogbert did?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
