Adding ballast to the pro set up
    Curious as to what people are doing for adding extra sacs not going to plumb in im thinking of setting on the floor basically. I would like to add around another 1,000 to 1,500lbs i already have the prop issue solved with an ACME 1235 we had experimented with it last year some but curious as to what other people are doing out there also.
    Are you looking to get a better wakeboard or wakesurf wake? What shape and size characteristics of the wake do you prefer to ride?
    I think madmike has the wakeboard wake dialed but he runs quite a bit of weight. Sounds like he has more of a 60/40 split with bias toward the stern.
    madmike's Setup -
    300 in the very very front.
    440 in the front on the floor.
    2 540's side by side in the back on the floor, but only filled up to about 400lbs each.
    If I have people in the boat, I usually don't fill the 300 in the front.
    The taps is at 1 or 2.
    Speed is 23.6 but could go faster.
      Better wakeboard wake how far out are you riding?
      can i get a pic of the wake with this set up
        Here are some good pics of Mike's wake.
        http://www.tigeowners.com/forum/show...madmike&page=2
