I visited my 24Ve in storage today and spent some serious time planning for my ballast system. I'm a little baffled as to where most folks put their intakes and pumps.
For many boats, I see lots of photos showing intakes and pumps being installed in front of the v-drive and behind the fuel tank. However, that space is rather small on my 24Ve - and it's not accessible without tools (a section of the seat must be removed) so accessing the shutoff valve(s) would not be quick in an emergency. I have a photo of this small space:
Beside and behind the v-drive/transmission, I have the triducer on one side aft about a foot and the engine cooling water intake aft about a foot on the other, plus lots of hoses and other obstructions. No real room there, since I don't want to install intakes in front of either of those existing thru hulls.
That leaves the area behind the engine ("bilge"). The rudder's cable and swing area take up the center. The muffler and exhaust take up the port side. That leaves the starboard side, an area very approximately 8-10 inches wide (between the keel and a large stringer) and perhaps a couple of feet long (from the transom extending toward and under the engine and transmission oil intercooler). This appears to be the only reasonable place that still might be accessible and won't interfere with existing fittings.
Given this limitation, I'm tempted to go with a single large (~1.5 inch) intake and a manifold. There's great controversy surrounding manifold systems, and I'd go with separate intakes except that I'm not sure there's room for them. A single thru hull could turn a 90 through a single valve and then T to each of three pumps, taking up less overall surface area than if I used a separate thru hull, 90, and valve for each one.
There may be space on either side below the battery platform, and the TAPS box platform, but I haven't yet tried to remove those and see what's under them. It may be structural foam since I don't have factory ballast.
Where have others put their intakes and pumps on 24Ve's?
