for a 2006 24V: where would be the best and easy place be for the water pick up for an intergrated front bow sac? Thanks
Intake for ballast
What Type of pump will be used?
I would recommend a 3/4" bronze thru-hull mushroom topped with a ball-valve. Depending on what type of pump, I would look to mount it some where that would allow access to the ball-valve if needed, but allowed clearance for the pump or plumbing, but was not directly in front of the speedo and depth pickup.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Expert
- Sep 2007
- 2409
- Manitoba Canada
- '06 Wakesetter VLX, Prev '06 Tige 24V - '03 Tige22i - '99 Sunsetter - '99 Tige 21i, -'96 Ski Chall
How about under the port side console? The wood floor does not extent right to the edge of the hull. Could I put it under the front bow seat closer to one of the consoles? I guess I would have to be careful and not install where the floor is.Life is good...
Happy Wife Happy Life
Originally posted by Dave K View PostI was hoping to just use an aerator type, Tsunami or Rule. Should it be closer to the front of the boat?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Expert
- Sep 2007
- 2409
- Manitoba Canada
If it was mounted closer to engine then I would have to pull up the floor right? I am not over concerned that I would have to have the boat stopped to fill bags.
In case of emergency, I was thinking of a 3/16" rod about 3' long somehow attached to the end of the shut valve handle so when we open hatch we don't have to reach right down close to the bottom of the boat.Life is good...
Originally posted by Dave K View PostIf it was mounted closer to engine then I would have to pull up the floor right? I am not over concerned that I would have to have the boat stopped to fill bags.
In case of emergency, I was thinking of a 3/16" rod about 3' long somehow attached to the end of the shut valve handle so when we open hatch we don't have to reach right down close to the bottom of the boat.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Ideally you would want to have the intake as far forward as possible when using aerator pumps, but unfortunately Tige doesn't install an access port in the floor forward of the gas tank, so it will have to be back in the engine compartment next to the transmission and v-drive (it can be installed there without removing the floor).
Under the bow seat is not an option, as you can't access the hull in that location. Plus, although you don't think filling under way it a priority now, you'll thank yourself for installing the intake further back in the boat.
We've played around with rods to actuate mechanical ball valves remotely, but because of the layout it's very difficult to set something up that generates a large enough moment about the internal valve. The rod needs to be oriented very close to 90 degrees from the handle, which is difficult to do for both opening and closing.
Since you'll hopefully never need to access the ball valve (it's only used for emergencies), it really only needs to be installed somewhere that you can get to within a couple of minutes, and the engine compartment is fine for that.WakeMAKERS.com | WakePROPS.com
Tigé Expert
- Sep 2007
- 2409
- Manitoba Canada
The third intake if I have it at the back engine compartment would I just run the fill hose up the port side and hook it into the port side top of the intergrated sac? That would mean the left side of that sac would fill first on once that side is full it would drain into the right side correct? I was thinking that the top middle plug in the sac should be the vent line?
I like the idea of the 3 intakes going through the transom. Is that ok or should I go through the bottom of the hull. I have read through the other post on this and understand the pros and cons of each, but which is easier and or better?
Thanks Guys..Life is good...
Originally posted by Dave K View PostThe third intake if I have it at the back engine compartment would I just run the fill hose up the port side and hook it into the port side top of the intergrated sac?
Originally posted by Dave K View PostThat would mean the left side of that sac would fill first on once that side is full it would drain into the right side correct?
Originally posted by Dave K View PostI was thinking that the top middle plug in the sac should be the vent line?
Originally posted by Dave K View PostI like the idea of the 3 intakes going through the transom. Is that ok or should I go through the bottom of the hull. I have read through the other post on this and understand the pros and cons of each, but which is easier and or better?WakeMAKERS.com | WakePROPS.com
Tigé Expert
- Sep 2007
- 2409
- Manitoba Canada
Originally posted by jason@wakemakers.com View PostYep, we typically run up along the stringer next to the fuel tank, and then up into the storage compartment behind the observer's seat back where we mount a vented loop. From there, down and into the port on the leg of the Integrated Bow Sac. That can be a little more work on a boat without a center ski locker or access panel though, so it may make more sense to run out to the perimeter of the boat between the rear seat bulkhead and the rear storage compartment, and then up under the gunnel to the bow of the boat. You can mount the vented loop anywhere in there.......
If I have each fat sac vented do I need a loop in the fill line if I use a 1 way gate value?Life is good...
Originally posted by Dave K View PostSo I would have to take the fuel tank access panel off correct?
Originally posted by Dave K View PostIs it pretty easy to drill that hole in the floor and get the fill hose to that point.
Originally posted by Dave K View PostIf I have each fat sac vented do I need a loop in the fill line if I use a 1 way gate value?WakeMAKERS.com | WakePROPS.com
Tigé Expert
- Sep 2007
- 2409
- Manitoba Canada
If I go through the bottom of the boat with brass thru hull connectors (Not a scoop) would there be a signifigant force of water that would continue to fill the fat sacs?
Could the water in the fill line reverse itself and flow through the pump and empty? Would the pump allow water to escape? I suppose check values are required on ALL fill lines? With check values it would rescrict the flow to the bags somewhat wouldn't it?Life is good...
Originally posted by Dave K View PostSo I would have to take the fuel tank access panel off correct? Is it pretty easy to drill that hole in the floor and get the fill hose to that point.
I can probably dig up a pic if needed.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
