Originally posted by WABoating
View Post
Ballast Pump Flow Comparison
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by chpthril View PostTherefore, I dont have a baseline to gauge off of and will will not know it the Y'd setup improves flow or not.
I suspect you'll know when you reach "full" by the sound of the pump. That's close enough to yield useful data.
Originally posted by WABoating View PostThat's why I said it would be approximate. If it only changes a by a few seconds, it's not worth the extra hardware anyway. If it changes meaningfully, then absolute numbers aren't as important as knowing that it made a difference.
I suspect you'll know when you reach "full" by the sound of the pump. That's close enough to yield useful data.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostIf I had an industrial scale, then I could base the cutoff point (baseline fill time) on the sacs actual weight and not when it begins to purge out of the vent (purging is more like a real-world ballast setup, rather then actual weight in a sac), so without that, the numbers would be skewed as compared to the numbers the pump delivered originally. This would lead to a false positive or negative.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Originally posted by Ewok View PostYou could use a lever and a bathroom scale like you would to find your trailer tongue weight.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Hey, it doesn't have to be all that complicated. Just run the test and listen to the pump. When the bag appears full and the pump changes sound, call it full and stop the timer. Simple as that.
Originally posted by Ewok View PostAre there any repair kits someone could get to add fill ports to a bag?Attached FilesMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by chpthril View PostThese can be glued in and mate with the 3/4" Fly High female quick-conns.
Now all that's left is to actually run the test.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
No, let's stick with what chpthril has already used. I'll be thankful if he just uses the existing 800 and 1200 pumps, since we already have data on them. Let's not discourage him from running the test by piling on more and more variations.
I don't expect chpthril to add these extra ports to bags he has not sold yet.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
To be honest, I think he has proven that there is not a lot of difference no matter what you do. Since the slowest was 5:45 and the fastest was 4:29, I think you are hard pressed to think that saves any of us very much time on the water filling or emptying sacs. Amplify this for a 1200 pound sac and we are still talking a little over 3 minutes difference, which we probably waste that much time before we even decided to turn the pump on.
I predict that there will be very little difference between a Y split into 2 ports and a single 1 inch fitting. If you watch the way a 1 inch drain shoots out water, then there is very little excess pressure, whereas the 3/4 inch ports shoot water pretty good. I have both on my boat and it is easy to see that the 3/4 inch discharge hose on a Jabsco pump shoots about 4 feet from the boat and has a sort of spray to it, whereas the 1 inch discharge has about 18 inches of discharge and has more of a chuga chug sound to it as it falls into the lake. If that makes any sense.Be excellent to one another.
I agree with Tall. I just gutted my ballast system in an 02 xstar and gave all three pumps its own through hull. I am glad I stayed with Ballast Puppy instead of changing out to the aerator style pump. I think with all the possible issues that come into play those styles and extra tubing what you gain in speed you lose in hassle and cost of fittings etc. Even though more expensive glad I stuck with my puppies. I do realize the pumps are $200 bones but seem pretty bullet proof mounted properly.
