21ZX Starboard Ballast Bag won’t fill
    New to us 2022 21ZX. Went out yesterday for the first time and things worked as expected. Then went out a couple hours later and the starboard bag didn’t fill. I emptied, powered everything down, tried again and no luck. When we got back to the dock we turned on just that ballast fill via the touchscreen and it sounded like it was running. New here so looking for things to check….
    Sounds like the leak is related to the fill line. Hole ribbed in hose maybe?
      No water in the bilge area. Took it out this morning - all pumps running and now neither rear bag will fill. Front bags do fill.
        Looks like we got it sorted - checked pumps for airlock or blockage, adjusted fill timers to run longer and all seems to be working again. Not sure what part fixed the problem, but kids are again happy and surfing .
          Do you keep the boat on a lift, sometimes they will get airlocked. Just hit the fill then reverse the boat hard to force water that direction.
