2013 Tige Z3 - Out this weekend and bags will fill but none of them will drain. You can hear the pumps running but no water is emptying. It's weird that they all stopped at the same time. We used the switch on the panel and it would drain from one bag for a short time and then stop. We had to manually empty them by removing the lid on the pumps. Screen is getting harder to press each time out so we originally thought it was that but override switch doesn't work either.
None of the ballast bags will empty even with switch on panel
Originally posted by bsreid View PostWhen you put the lid back on the pumps did it change anything? Potential air lock but that should have fixed the issue. I would follow the line back make sure no kinks or bad check valves.
Not normally. Was this your first time out for the season? Sometimes after being winterized and completely drained they will airlock for the first time. Reading your post again you say it drains for a bit which indicates the pumps aren't air locked, unless it was just overflowing out the vents.
Originally posted by bsreid View PostNot normally. Was this your first time out for the season? Sometimes after being winterized and completely drained they will airlock for the first time. Reading your post again you say it drains for a bit which indicates the pumps aren't air locked, unless it was just overflowing out the vents.
