I’m in search of where I can find either the origin ballast hose mfg or someone who makes them like the original. Originals are much more flexible than wakemakers.
Thanks
Not a 100%, but IIRC, it was the Shields 149 series. With that said, I have found this hose does not last as long. Even with its coil reinforced center, ive seen it collapse. I use a similar (same actually, just a different color coil) as the ballast retailer you mentioned, for all my kits and installs.
