So I’m draining approx 5+ gal of water out of boat after surf sesh(i.e. filled ballast)…water doesn’t drain when level, but I discovered when going up hill, water was draining out, when I stopped n checked, it drained for over 5 min. I assume I have a leaking ballast…but when I fill and empty ballast I don’t see a bad leak that would leak as much that drains…sure they all leak a bit here n there.
I can’t access driver side ballast.
1. Should I be concerned if water isn’t draining when level?
2. Should I bother asking Tige dealer service to find leak…being as it will prob keep happening..or$$..??
can’t imagine it’s good to have that much water sitting in hull.
It is a pain to find a hill to drain water after each lake sesh. though.
