Where to put fill/vent on front sac
    Hey guys I got a new port side ballast bag and this one had three hose lines as opposed to my last bag which had 2 vents, 1 fill and 1 drain.
    My initial thought is that I would put the fill at 1, drain at 2 and vent at 3. Does that seem to make the most sense? Thoughts? Thanks.
    Is that a bow bag? I would switch the fill and drain so the drain is on the bottom. Also assuming 3 goes forward so when bow high it is the highest point.
      Drain needs to be a fitting thats located low on a sac wall. Vent needs to be the highest fittings so air keeps purging as the sac fills. 3rd fitting would be fill. So if the pic above is how the sac would be oriented, then 3 = vent, 1 = drain 2 = fill.
        Thanks thats what I was ultimately leaning towards as well but wanted see what others had to say. I will say that Tige had it a bit different in their stock configuration which made me second guess things. I still dont know why they had 2 vents.
