I just ripped out my hard tanks on my 2008 RZ2, and moved the batteries looking to get custom bags to made. I've emailed and PMed Mikes Liquid Audio, but haven't had any responses from him. Does anyone have recommendations on where to get these bags made up? I have lots of room to fill.
Recommendation on custom ballast bags?
Check you email in-box, replied about 20 mins ago. I am ballz to the wall full-on into the upgrade season.
That pick answers the question I was getting at in my email. No locker wall, but going all the way back to the transom, or are you goin to build new back walls as if the boat was built with no factory ballast?. We would need to do a 1-off of my existing design to add a little extra to the end of the sac, if extending to the transom. Thats not a big deal, just need to get some dimensions.
Are you going to move the TAPS pump? I would not want the weight of the sac resting on it.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by kdammen View PostI just ripped out my hard tanks on my 2008 RZ2, and moved the batteries looking to get custom bags to made. I've emailed and PMed Mikes Liquid Audio, but haven't had any responses from him. Does anyone have recommendations on where to get these bags made up? I have lots of room to fill.
Moving the batteries was super easy. I just coated plywood in some fiberglass, and mounted the batteries on them. All my wiring was long enough, so no splicing. Everything is so much easier to access without the hard tanks in place. I had to reseal the swimdeck bracket, so the hard tank had to come out anyway.
The tanks were not too bad to remove. I cut the hoses and wiggled the tanks out in one piece. The whole project took less than 3 hours. I still have to build new walls, and that could take some time.
Originally posted by JWehrheim View PostI have an 08 RZ2 and did the same thing but didn’t move the batteries behind the motor just moved all the way back.
I used HDPE for the panels and installed aluminum U channels on the floor.
I ordered full custom bags from Wakemakers based on my measurements.
I just placed my order with wakemakers too 2-3 weeks. I was able to get 1165lb bags in stopping just behind the cupholders. So I don't loose any under seat storage space. If I were to move the batteries all the way to the back wall I wouldn't loose much ballast. Probably would have been a bit easier, but I liked them behind the engine since that was dead space anyway.
Originally posted by N.Penley View PostKdammen,
What material are you using for your side walls? I am considering using Starboard (or a knockoff) composite rather than coated plywood if I need to upgrade mine after ballast. I hate the idea of putting wood in a boat after dealing with transom rot in my last ski boat.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Thanks. That’s good to hear.
BTW I just emailed you and am stoked to get my ballast installed.
Sent from my iPhone using TapatalkMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
