Hey all, just bought a 2020 22rzx. We have put about 30 hours on it and bought it with around 10. I just noticed the aft port ballast hose was leaking water right above the plug and play. Looked at it better and there were 5 punctured holes in the hose. above the hose were a few screws sticking out. And possibly a few other metal pieces that could’ve punctured it. Is this a normal problem? Is something missing that should be protecting the hose? Do some wakemaker hoses have punctures already or did it happen because of use? How easy is this to fix? Thanks
2020 22rzx ballast hose problem
Originally posted by UNSTUCKI'd rather fix a bad bag than a bad tank. Many reasons why a bag is better than a tank. Can't think of any why a tank would be better.
I can’t image what must be done to get tanks out? Separate the deck from the hull?
Originally posted by maxrider View PostI don't know why they still use bags for the sub floor. ( Well i do it is cheaper) Only thing I do not like about my boat is the sub floor ballast are bags. Kind of sad for a 140K boat to use such a cheesy design.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
So I guess a G25 Paragon is out of the question for low quality?
So when you say "mold the tank into the boat" you mean leave a cavity and have it fill and drain as a tank/sac? Still run the risk of a port failure. if this happens, the fix might be an new boat, as now the "hull" has failed. Besides, im not sure on the longevity of water in something thats not a polly hard tank or heavy vinyl bladder.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
G boats have 3 soft sacs and if the hard tank on a Centurion fails, and they have, you have to separate the deck cap from the hull to repair. I also think the Malibu M series has sub-floor sacs, but not 100% sure of that.Last edited by chpthril; 07-10-2021, 09:05 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I dont disagree on the hose point. Hose routing and length is the leading cause of fitting failures. We've been addressing it for years. I was just commenting on the correlation made between tanks and perceived quality.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
