I have a leak either in my rear ballast piping or drain pump. Chpthrll suggested checking for a leak in the drain pump. I am assuming the pump is located under the false floor in the rear locker. Any pointers on how to remove the floor to access the pump. Thank .
RZ2 rear ballast drain pump access
Originally posted by BCRider View PostThe pump is at the back of the hard tank up against the stern of the boat....ie straight down from the Taps pump or below the batteries on the port side. I've never pulled the floor but you'd have to remove the engine divider walls and rear walls for sure. Not sure how it may be secured after that.Oh Yeah!
What the brackets material and function? Id look at fab'ing one and calling it a day.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
