2018 Tigé R22 Ballast Bags
    We have a 2018 Tigé R22 that we just purchased used with only 40 hours. We have taken the boat out a few times and filled the ballast to surf with. After a few times we felt like the bags weren’t filling all of the way up like they were supposed to. We were told the bags should fill so much they look like they would pop. After taking it out yesterday, we noticed that all the bags only fill 1/4 of the way up and that the rear port side was filling 75% of the way every 3rd time and the rear starboard side would fill 1/4 of the way then bypass to the drain and the water would go out the drain port. There is also an error showing on our screen now when we go to look at everything.
    Sounds like there is an issue between sub-floor hard tank and the locker sac, tank fills, sacs fill a little, but no more, water is forced out the vent or drain.
      How would you suggest fixing an issue like that if that is the problem? I don’t think our boat has hard tanks.
