Any of you have problems with the deck dragging holding you from speed from to much ballast?
2001 2100v Ballast
Originally posted by AJMichael View PostHmm, engine is running good, new trans and 911 prop but was stuck at 10, boat would not pull speed.
I'd wager on weight distribution, not enough weight in the front.
If the bow is too high the prop is making too much upward force and not enough forward force and you end up just plowing along.
Next time it does that send people to the front and see what happens.
For a direct drive, or a V-drive with a black 1:1 ratio unit, a 3 blade would the most ideal prop, and the 911 is a stump puller.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Nah, just muscle memory. Its where my brain goes when talking props on boats this generation. Seen WAY to many use the suggestions from that other place, only to be the wrong prop for this very reason.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by SONIC View Post
What color is the Walter? Blue ones are 1.5:1 and black ones are 1:1Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I'd love to get some advice on this same topic. I bought a 2000 21V this spring and have been working on getting a wave that I can consistently surf with no rope. Not there yet.
Currently, I have a 750lb fat sac on each side of the engine and a 650 in the walkway in the bow. I usually only have my wife driving and one kid in the boat. I'm using a Wakesurf Edge shaper and surfing on the regular side. I put the wake shaper all the way back towards the transom and just above the spray pocket. I got the Wakesurf Edge with the narrower suctions, so it can fit in the spray pocket, but for some reason when I put it there it slides off the back of the boat. I'm 5'9" and 150 lbs.
I get the best wave with the taps at 9 and speed at 8.8. I know that is slower than what everyone else recommends, but the wave really flattens out above 9 mph. The wave is great and I can surf with no rope when the boat is right around 8.5 - 8.8, but as it slows below 8.5 the wave washes out and as it speeds up over 9 it flattens out. I have Perfect Pass engaged, but the speed still varies from about 8.3 - 9.3 when set at 8.8.
Any suggestions on getting a more consistent wave?
I'm just using an over the side pump right now, but would like to plumb everything in (and get a v shaped bag for the front) this winter, but want to get the wave dialed in before spending the money on a more permanent set up. I'm hoping to avoid lead in my permanent set up because I store my boat on an older Basta lift rated at 4,000 lbs, so I'd like to be able to pump all the weight out before lifting it.
