Good evening. I have a problem with my 2013 RZ2. A few years ago I upgraded the rear bags to 1000 lb (I think) fat sacs. My son surfs goofy so this weekend when filling the starboard sac, I notice water coming out of the side - I thought I accidently hit the drain button, but it turns out that bilge pump had kicked on. I look in the engine compartment and I have a pretty good amount of water coming from the rear starboard drain hole. I shut off the ballast pump and the water eventually stops leaking in.
I put the boat back on the lift and removed the fat sac, went back out and turned on the starboard rear ballast pump and had the hose over the side, pumping back in to the water and I still have water filling the bilge. I check out the pumps and don't see anything leaking around the pump. I am not very familiar with the routing of the fill hoses, is it possible I have a split hose under the deck somewhere?
Thanks in advance,
John
Thanks in advance,
John
