Hi all,
This last Sept. I got a screaming deal on a brand new 2008 22ve from my local dealer. It didn't come with any factory ballast and the wake is good for wakeboarding, but surfes only decent for lighter people with 5-6 in the boat. I am 6'6" and 250 lbs and I am not one of the light ones! I know ChpThril has posted saying to put a W705 in each rear locker (60x26x10 for 650 lbs.) and the W706 for the bow (54x54x54x12 triangle for 1,000 lbs.).
I pose a few questions here. Why use the W705 in each rear locker instead of the W707? Is it because the W707 (50x20x20 for 750 lbs.) won't fit with it being too tall to fit under the angled forward wall of the locker? If not it seams that the W707 would be a better option. the W701 sounds good too (42x16x16 for 400 lbs.) but I assume it doesn't hold enough weight. How far forward (ie how much storage space will I lose for the underseat space) does the W705 go (an answer other than 60" would be appreciated
The next question is about the weight in the front. As opposed to doing the W706 and making the front seat/filler unusable for people, is there anything that would fit in the walkway under the filler cushion and provide enough weight? I was thinking something along the lines of the W703 (48x12x12 for 260 lbs.) and putting another person or two in the front while surfing. Is that even worthwhile/provide enough weight or is it best to stick with the sac to fill the entire bow?
Any input would be greatly appreciated. I am not able to measure the compartment since I have the boat at the stereo shop getting the WS stereo components installed
If any of you members sells the Fly High sacs and Tsunami pump let me know and I can get the stuff from you. Oh yeah, not looking to plumb in the system, just manually fill it.
Thanks for your help!
Bryce
Bryce
