Mainly we wakeboard, have one or two that like to surf a little so looking into more ballast... already have the 900 lb factory; dealer said he would install everything I wanted. So my question is what would be the best set up for wakeboarding primarily and maybe a little surfing.
Ballast Suggestions for 2009 22Ve
I would consider using a W707 (20x20x50 & 750 lbs when full) for the walk-way, and a pair of V-drives, W701 V-drive sac set (16x16x42 & 400lb's ea) for the rear lockers.
For surfing, use either the W707 or 1 or both V-drives in the locker on the surf side.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Assuming that your dealer is going to install an automated system, I would recommend a W707 in each rear locker that you only partially fill for wakeboarding, but fill completely for surfing. That will allow everything to be controlled from the dash, without the need to swap bags depending on what activity you're doing.
Up front a W711 Integrated Bow Sac would probably be the best fit in your boat, and offer great weight distribution to maintain the correct shape wake so that TAPS works properly.
Using our PiggyBack systems you can upgrade the factory ballast in your boat with little to no mechanical skills, that's one of the great things about the factory ballast system in 2009 and newer boats.WakeMAKERS.com | WakePROPS.com
Originally posted by jason@wakemakers.com View PostAssuming that your dealer is going to install an automated system, I would recommend a W707 in each rear locker that you only partially fill for wakeboarding, but fill completely for surfing. That will allow everything to be controlled from the dash, without the need to swap bags depending on what activity you're doing.
Using our PiggyBack systems you can upgrade the factory ballast in your boat with little to no mechanical skills, that's one of the great things about the factory ballast system in 2009 and newer boats.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostHis 09 already has a bow sac as part of the factory ballast.WakeMAKERS.com | WakePROPS.com
Originally posted by jason@wakemakers.com View PostYep, I know, I was suggesting an additional 711 up front, a lot of our Tigé customers have been really happy with that setup, and it allows them to run more weight in their rear bags without the wake crumbling (like you mentioned).Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
