does anyone know if a tsunami t-800 is strong enough to push open a 3/4 or 1" check valve? or will this cause to much restriction? im betting that a swing check will work better, but i already have them after 2 of my pumps, and sometimes they get stuck shut and i have to reach down and shake them a little bit to get them to open. just thinking of trying something else.
restriction question.
Originally posted by laketime View Postdoes anyone know if a tsunami t-800 is strong enough to push open a 3/4 or 1" check valve? or will this cause to much restriction? im betting that a swing check will work better, but i already have them after 2 of my pumps, and sometimes they get stuck shut and i have to reach down and shake them a little bit to get them to open. just thinking of trying something else.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
yeah i would be using it after the fill pump, and it is a plunger style valve. and really? you don't need a check valve there? it wont empty itself??
and i agree i think swing checks are probably the best way to go. but im using old inventory parts from our shop, so i've used all the old swing valves and all i have left are the plunger style.
I still like the plunger on the vent, cause even though causing issues, I need those babies full, and stay full. But here is where to get the swing valves. I am going to drive to this place on saturday.
http://www.plumbingsupply.com/pvccheck.htmlhttp://wake9.com/
Originally posted by laketime View Postyeah i would be using it after the fill pump, and it is a plunger style valve. and really? you don't need a check valve there? it wont empty itself??
and i agree i think swing checks are probably the best way to go. but im using old inventory parts from our shop, so i've used all the old swing valves and all i have left are the plunger style.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by laketime View Postso this is going to befor my front sac. if i run from the manifold in the back, up as high as i can in the side srorage area, then drop down to my fill port that should be enough even under exceleration that it wont siphon?
I did mine that way, running a pair of V-drives, and had no siphoning. I put a c/v in the front fill line, but after I got the hose run up front like I wanted, it when up and over the bulk-head wall and was way higher then the bow sac, so the c/v ended up not being needed as bell. In the fill lines, a c/v can contribute to the vapor-locking in the pumps, if the c/v is mounted vertically. Water left in the hose sits on top of the flapper and does not allow the air trapped in the pump to purge. Xpjim discovered this on his and eventually removed or relocated them.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
