I paused on the dual fill for a min. The tank and hull are already set up for dual fill, so it would involve a cap of sorts on the tank and not drilling the hole for the fill fitting. Then what are you saving but the hose, fitting, ground strap, some labor.
Rumor Mill!
Originally posted by freeheel4life View PostThats a nice list Mike. Theres even a few more things that could get taken off the list but why would you want to (dual fills, and GPS swapped to a paddlewheel).
I wonder if they could run a 1:76 instead of a 2:1 and if there would be any saving?? Theres some others running the 1.76:1 and pushing big weight at elevation but Ive only seen that optioned with the next step up from the 440(SC calls it the 450 but I believe Indmar calls it the 460). So Im think any savings in the power train gets gobbled back up by the higher optioned engine.
No savings though....Germaine Marine
