Originally posted by PaceWithGrace
View Post
Tige TouchPad Upgrade Project Thread
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Update: On water testing today! All of the functions are working fine. You can navigate the menu system, select things, turn on cruise control, set and adjust speeds, the works. When it's in the dash you wouldn't know that it isn't the OEM panel - except that it works and it's reliable.
Since we all love photos around here, this is one of the prototypes installed in a factory bezel, with the OEM assembly sitting next to it. You can see that the new board just drops right into the bezel like the old one. We're even using the same screws.
Here's that same prototype connected to the boat during testing.
Yes, the new unit will have flying leads with a connector at the end. As mentioned earlier, the enormous, expensive, and unnecessarily water-resistant 12 pin connector on the original design has to go somewhere. The original unit put the center snapdome on the flex circuit (the component that fails all the time), allowing the connector to also be centered since it solders to the (separate) PCB. In our design, there's nowhere to place the connector that doesn't either interfere with snapdomes or LED's, or is likely to require cutting a larger center opening in the dash. We want this to be a drop-in replacement that anyone can install, so we're going with the flying leads. The wiring harness is loose wires too, so it really doesn't change anything.
Don't worry about the "extra" components visible on the new board. That's why you build prototypes.Sometimes you don't know the final values for certain components until you actually build a prototype. In this case, the debounce characteristics of our board, the snapdomes, etc. can't be modeled reliably... you have to build one and actually measure it. (I could show you the scope traces but I doubt anyone cares.) Those components will be properly integrated into the board design when we rev it for production.
BTW, the backlight LED's DO come on in this 2009 24Ve when the rest of the dash lights come on, so we're glad we duplicated that functionality on the new design.
Testing continues... more soon!Last edited by IDBoating; 04-27-2016, 08:20 PM.
Are you not worried about the pads getting torn off? The lack of strain relief would be of major concern on any of my designs. Especially with the heavy deutsch connector and the strain that poor sea conditions could cause.
I hope you see this as constructive criticism. It should be possible with some changes to deal with this issue.
I'd hate to see this resurface again in a year's time!
On another note I think your scare tactics for selling them are perhaps a bit extreme. Holding a small stock of inexpensive pcb's for the season is all about good business. But I totally understand you wanting some upfront commitment.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by chrissnow View PostAre you not worried about the pads getting torn off? The lack of strain relief would be of major concern on any of my designs. Especially with the heavy deutsch connector and the strain that poor sea conditions could cause.
Hand-assembled SMT boards are fine for prototypes. I don't consider them professional enough for shipment. Perhaps you have different standards, but we want to ship each one of these once and never have to think about them again. We want buyers to have the same peace of mind.
Thanks!Last edited by IDBoating; 04-27-2016, 10:30 PM.
Thanks IDBoating! Do you know your touch pad will affect how the speed set functions? I have an 06 24VE. When the speed is set and you are throttling up, it will overshoot the set speed by up to 5 mph. I have heard the 07 speed set doesn't do this. This may be a dumb question but does your version affect this at all? Thanks in advance!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by efrickle View PostI have an 06 24VE. When the speed is set and you are throttling up, it will overshoot the set speed by up to 5 mph. I have heard the 07 speed set doesn't do this. This may be a dumb question but does your version affect this at all?
Originally posted by efrickle View PostThanks IDBoating! Do you know your touch pad will affect how the speed set functions? I have an 06 24VE. When the speed is set and you are throttling up, it will overshoot the set speed by up to 5 mph. I have heard the 07 speed set doesn't do this. This may be a dumb question but does your version affect this at all? Thanks in advance!My life's journey is not ending up looking pretty, its sliding in broadside, used up, worn out, screaming "What a Ride"
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Today's update: With on-boat testing we've discovered that the plastic bezels/frames aren't always perfectly flat. Not surprising for a low tolerance injection molded part. But when the PCB is installed into the bezel, the two pull on each other and this affects the spacing relationship between the elastomer (the rubbery piece that you actually press with your finger) and the snapdomes. If all the tolerances accumulate just right (wrong?), it can affect a snapdome's ability to relax back after actuation and release. This effect is not consistent across multiple bezels, i.e. the variations are different with each one.
Fortunately, we have found that a spacer of the proper thickness between the PCB and bezel solves the problem. Even more fortunately, there is an easy way to get such a spacer: Use a "snapdome cage". These are adhesive mylar sheets generally used on large arrays of snapdomes to insure proper alignment, and we weren't going to bother on these boards with just seven snapdomes. But adding a cage will allow us to easily obtain the spacer we need anyway. It will add a bit of cost for tooling and then materials, but it won't be significant. It will also ease assembly somewhat, so we may make it up in labor expense.
If these minutiae are boring, let me know and I'll shut up.But this particular project has a lot of interest so I thought folks might find a running commentary entertaining.
We'll keep you posted!
Originally posted by IDBoating View PostIf these minutiae are boring, let me know and I'll shut up.But this particular project has a lot of interest so I thought folks might find a running commentary entertaining.
Supreme device please email me with the following information I am coordinating the names for him.
Name
Address
Phone number
Email me at thegerman618@yahoo.comMy life's journey is not ending up looking pretty, its sliding in broadside, used up, worn out, screaming "What a Ride"
