Howdy, I replied to your email!
Tige TouchPad Upgrade Project Thread
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by Jcloward5 View PostHey IDBoating what is the fastest way to get an order for the replacement speed set control and do you have them in stock for an 07 RZ2? Thanks
Thanks!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by Grebva3 View PostNew to the forum. I have a 2006 20V with the MP 340. Do you still have in stock the accuset touch pad?
Here's the link to the order form: http://waketouch.com/media/TigeOrderForm.pdf
Thanks!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
It fixes the "buttons not working" (or burned out lights, etc.).
The panel alone cannot fix the "freeze up" or "drop out" problem seen by many people, because the actual logic behind the cruise control in these boats is implemented in the engine's ECU (the electronics package on the engine itself). The panel sends instructions to the ECU to set the desired speed, increase or decrease it, etc. But once the speed is set, the ECU handles throttle control.
That "drop out" problem is well known and very frustrating. We don't know if it's a problem in the ECU firmware, or in the Medallion firmware behind the helm, but we strongly suspect the latter because in most cases when it happens the little LCD screen also switches away from the cruise control display to the "Main" screen. If the problem were local to the ECU, the LCD would be unaware of it and have no reason to change modes. Another telling detail is that in most cases the cruise control continues to maintain the set speed even if the screen switches modes... again suggesting that the problem is not in the ECU, but in the helm display firmware.
Medallion did issue at least one firmware update for these units a long time ago, but as far as we've seen it did not eliminate this cruise control screen problem.
Originally posted by IDBoating View PostIt fixes the "buttons not working" (or burned out lights, etc.).
Guess I should probably order one of these. I still have the original one in my 09 22ve.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
WakeTouch is opening a new location in Tennessee, and Tige SpeedSet touchpad orders will be accepted and shipped from there. The updated order form is available by clicking here. Price, etc. is all the same, only the mailing address has changed for those who prefer to mail a check.
Thanks!
I've been following this project with great interest—excited to see the progress! If anyone's looking to get into ICOs (Initial Coin Offerings) and explore potential investments in emerging technologies like touchpad upgrades, I recommend checking out ico crypto. It provides detailed information on various ICOs, including their goals and technical aspects, which could be useful if you're considering integrating crypto technology into your projects or investments.
