good wright up Boss, All you R20/RZR owners..Look for more info from Tige.....Its on.
Tige Wakesurf Device - BGB?
Originally posted by Timmy! View PostWhat would this do on the RZ2/4 or 22/24Ve's that don't have this spray issue?
Every boat we have surfed on has some settings that work, and some that don't. The point here is to make a wake that works over a huge range, providing maximum adjustability.
This picture says it all to me. Represents all of the feedback we gave to Tige and their awesome engineering to produce the result.
http://wake9.com/
Not to discredit all the hard work and devotion that's been presented here, but I do think Duncan's idea is probably where all the boat manufacturers will finally end up. Platform, shaper, ballast, gate....one unit. Mounted on or glassed to the hull.
Duncan writes: Glass the deck and the BGB together in one unit, separate the interior into two compartments, and pump water into one side or the other of the compartment depending on wave side.
The above one piece rig would also provide a nice flat side to mount a vertical (surfgate) trim tab (fill both compartments) for quick switching of wave side. Given that the Z3 has such little lean to begin with, perhaps the trim tab would function on the wave opposite side just fine.
I was thinking of ordering a Z3 this upcoming spring. I would definitely add the BGB to it. But I am also thinking that I should wait a few more years. Let them work the bugs out and engineer something even better. Oh this conundrum I face."You're rather attractive for a beautiful girl with a great body."
Originally posted by Duncan View PostYeah, I am waiting a few years to buy that boat.
In the meantime, I will try out the strap-ons
This kind of stuff will surely get a bunch of self proclaimed engineers to work, and from their hard work and effort we will all end up with an ultimate strap on mod and share success.
So if one of you guys has the guts and glory to start work on an RZ4 stap on, give me a shout. I'll share cost.
Originally posted by ragboy View PostI have owned 3 of those boats, I think they all have wash issues. On the RZ2 for instance, weight yoru boat and run through the taps, not all positions are clean. Also on the RZ2, if you go taps up high, the wave distorts weird. This thing resolves that, clean in every position, plus longer, etc, etc. I can't wait to see how it effects and RZ2 or RZ4.
Or if the pocket is longer when its less steep.... let him start his charge as you steepen the wake and let him boost at peak.Mods: MLA BIG Ballast System (1800+ Custom sacs, 2 500 W705 sacs under bow), Duffy Surf Flap Mod, Trimmed Swim Deck, Top-Mount Starter
