Well she arrived and is installed.
I personally love it. Will do a full write up on it. but here is the high level over view. Bit of work for one person. So have a friend or spouse around to help juggle your speaker\mirror arm. Also plan on Buying longer bolts. The ones that where stock on my wet sounds where longer then the bolts shipped. (I called scott at samson before I started to get the 411 and they knew they might be short, and he offered to send me some longer ones, I declined but great service none the less)
ended u puttng in 5/16 2.5 ss bolt in with washer and lockwasher was perfect length.
just be prepared you have to cut your wet sounds wiring to get the speaker mount down. so have some wire cutters around. just re-crimp when you put back together not a big deal.
pretty slick install.. I love it so far. But then again she has not left the garage. will detail it more once she has taken on rough water ext..
