I was replacing the o-rings inside the trim tab of my 2006 tige 24ve and never having done it before, i made the mistake of pushing down the plate (instead of using a hose clamp) while unscrewing the shaft from the upper hinge. When it unthreaded completely the shaft busted free with some force and from inside the upper hinge, what I believe is the spacer fell out and exposed two wires. Did I just break this piece off?! I don’t see where wires could go into the spacer but where would they go to? Any help would be appreciated!
