No that is not a Metcraft tower. Looks like an early Samson tower
Any known problems on a 1999 Tige 21V??
Originally posted by dogbert View PostI own a '99 2100v Limited. Same boat as what you're looking at, just different trim level. I ordered it. It's been a great boat and we're up to 600 hours. We've been using it a lot (over 300 hrs in the last 2 years). I did have to replace the alternator (too much surfing) and fuel pressure regulator. Other than that just the normal maintenance items. The boat has a nice rampy wake and our surf wake is awesome. You'll want some ballast if you're an intermediate rider or better, but I can help figure that one out.
The boat is built like a tank.
If you don't mind sharing, what do you think about weighting down your boat? I have not had much time to fool around with mine and would not mind taking a short cut. The further and higher I can go the happier I amI had the right to remain silent, I just didn't have the ability. -Ron White
Originally posted by damanmrt View PostI am in the market for a use wakeboard boat. I have found a used 1999 Tige 21V. Were all the 21V's rider's editions? What is included in the rider's edition? Was there any known problems with this year, that I should check and make sure that they were done? Should I stay away from this year because any particular problems? I have read on another board that a few people have had v-drives problems, and another one had his replaced. Any info would be greatly appreciated.
Thanks
Originally posted by tabone1 View PostIf you don't mind sharing, what do you think about weighting down your boat? I have not had much time to fool around with mine and would not mind taking a short cut. The further and higher I can go the happier I am
1 350 tube sack in the ski locker on the passenger side
1 350 in the cockpit
1 Fly High integrated bow sack (it holds 750, but I probably only get about 550 in there)
1 150 lb sack in the walkway.
The wake is clean, big and rampy @ 21Mph.
Remember, this boat likes 50/50 or even 60/40 weight distribution (front/back).Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
I took a look at the boat that originally made me start this thread. The interior needs some work (rips, stiching coming apart), but more I am more worried about the motor. Here are some pictures I took of the motor. Is this normal to have rust? Is this Throttle body Fuel Injection can anyone tell? What was the typical HP for this motor? Any input would be great. Thanks
My 1999 2100V Limited came with a 315HP 350 Magnum MPI MerCruiser Engine and V-Drive 1:1 Transmission. See picture of engine the month I sold it (2006).Attached FilesLast edited by MRMoffat1; 09-18-2007, 03:50 AM.
Does this look like a MPI motor though? I looks like it has a fuel rail on each side of the intake. Whats under everyone elses plastic cover, since this one is missing the plastic? Oh yeah this is a 1999 2100V limited also. What does the limited say about the boat? It has taps, shower, and perfect pass. Everything else is pretty standard.Last edited by damanmrt; 09-18-2007, 04:12 AM.
