The last one is probably the best, except I'd add a check valve on the vent line so you always only have water in your Fly-High Sack. That way you will never suck air.
EK Ballast Install
Originally posted by dogbert View PostThe last one is probably the best, except I'd add a check valve on the vent line so you always only have water in your Fly-High Sack. That way you will never suck air.Originally posted by eks View PostWhat would that do to the pumps when there is nothing to suck? I know it sounds funny! "D
Would put too much stress on it?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Thanks all for your comments and expertise on the matter. It is a nice sunny day, about 60 today, and I think I will have some fun after work tonight trying to get some of it done.
I need to figure out the electrical problem first, then hook all the wires and pumps. I'll post some pictures later.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by chpthril View PostI think it would cause a hose to collapse once the bag is empty, if it the vent does not vent both ways. Draining from the bottom should allow the water to collect around the valve till near gone before sucking air. Because you are not draining out the side, you dont know when the bag is empty till the pump runs dry long enough to kick the run-dry switch. I dont think these pumps where intended to operate this way.
Of course, drilling holes in the bottom of my boat is never simpleCursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by dogbert View PostMakes sense. No check valves for me then. KISS
Of course, drilling holes in the bottom of my boat is never simpleThe laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
I figured out the electrical problem. One of the batteries was completely dead.
I guess one battery is 100% dedicated to the engine and that one was working just fine.
I took to AutoZone and the battery won't even take a charge.
What the crap! The boat is 9 months old, and 5 of those months the boat was in storage with the battery switch off.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by eks View PostI figured out the electrical problem. One of the batteries was completely dead.
When you get everything back together, run the engine, use a DVOM and check for Alt charge voltage on the new battery just to make sure all the wiring and Iso is ok.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostBatteries with low voltage will freeze, and then will never recover (take a charge).
When you get everything back together, run the engine, use a DVOM and check for Alt charge voltage on the new battery just to make sure all the wiring and Iso is ok.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by eks View PostDo you think I have a short somewhere?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I took the boat to my dealer to winterize and they said that they did turn everything off. I guess not.
I also notice that some of the items I asked them to fix as warranty did not get done. I am just a little upset of the quality of work.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by eks View PostI took the boat to my dealer to winterize and they said that they did turn everything off. I guess not.
Typical for taylors ek
