You also can leave the pump as is. Does not have tobe higher than the bag
EK Ballast Install
Originally posted by chpthril View PostI do think that raising the pump higher then the sac will stop the unwanted back-flow, but, the pump will have to work harder to prime up as the water will drain away from the pump on both sides when off. Each time these pumps run dry, it shortens the impeller life. I still think it's best/easiest/most efficient, to drain from the bottom of the sac
This is a crude drawing of how a guy on WW did his DIY Ballast Puppy install.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by xpjim1 View PostI agree with mike except for one item. You need a check valve on the vent line between the bag and the T or you will recirculate water bag into the bag when drainingMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by xpjim1 View PostYou also can leave the pump as is. Does not have tobe higher than the bagThe laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by chpthril View PostThis is a crude drawing of how a guy on WW did his DIY Ballast Puppy install.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
I'm wondering if the vacuum from the backwards scoop is the cause of the unwanted back-flow??????Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
You will only need 2 check valves per pump. One between the manifold and the pump and one on the vent line before the T with the drain line. Or if you fill and drain from the top of the bag you could get away with one check valve on the vent line and fill and drain through the thru hull. By filling and draining from top of bag you might lose a little water in the bag but not much. I am taking off my check valves on my fill lines since tehy are higher than the bagLet it be!!!
Originally posted by chpthril View PostI'm wondering if the vacuum from the backwards scoop is the cause of the unwanted back-flow??????Originally posted by dogbert View PostJust curious, what's the purpose of the backflow if you have a vent or are you saying it's in lieu of the vent?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
