Originally posted by talltigeguy
View Post
G-Money's ballast systems
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Originally posted by talltigeguy View PostNo one ever answer my question as to why he would go with a scoop and then mount it backwards. A mushroom would seem cheaper and easier.
The hose that you used might be able to kink, thus allowing it to stop flow. I especially hope that is not the hose on the overflow. If your overflow kinks, then your bag blows up.
Mental note to self: connect switches and pumps outside the boat and make sure they are labeled properly. I am sure it was a PIA to repeatedly crawl under the dash and rewire things.
Cheaper yes easer no......
We have a direct shot in to the manifold with out running any hose, used less 90 degree elbows and don't having to worry about the pumps priming. The pumps will fill in a few min so you do have to fill wile stopped, not a big deal because you have to stop to get your board on... But we can drain wile under speed so if we need to clean up the wake that is why it's on backwards. If it was facing forward the pumps would have a hard time pumping the water out under speed with the water being forced in from the scoop. We stole this idea from the new MC ballast systems.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Yes this hose can kink but is not likely we made sure it was all laid out so we hardly have any turns. Plus this hose is close to 1/2 price.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Originally posted by G-MONEY View PostIf the wiring on the switches was done correctly we would have finished it a few hours. BUT............ Jabsco cross wired something and apparently we are not smart enough to figure it out
Over all I was really surprised how simple and easy it was to install the system.
I just want to give a HUGE thanks to SPBFAN and Doms for helping us.Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Originally posted by xpjim1 View PostIn my diagram I my black wire from Battery is the yellow wire in the Jabsco harnessPut your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
With it mounted backwards when you are draining the bags you do not have to worry about overcoming any Head pressure, and backwards it actually creates a vacuum and pulls the water out faster. When mounted forward the pumps we were told would have a hard time overcoming the pressure of the water, esp while driving. At the volume they pump by the time G turns off the boat, and turns the pumps on the bags will be full before he even gets the rope out or the boards on.
I agree with this statement and this is the only part of the system I do not like. HOWEVER that being said this hose is so much cheaper and when installed correctly it will not kink. Each to his own, and they can always replace it. I'm not sure how the decision process was made on it. I was not involved in that.
Mental note to self: connect switches and pumps outside the boat and make sure they are labeled properly. I am sure it was a PIA to repeatedly crawl under the dash and rewire things.Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
xpjim
we just figured it out. I and was going to post the wiring and as i went through the posts i saw your last sketch....exactly like ours. Thanks everyone, Much appreciated. Just so you know looks like there is a diode in the switch and if you are not careful it may be mistaken for a short........Will try this tomorrow and see what happens.......
