Third Party Ballast System
anhaney
Originally posted by chpthril View PostYes, but I you can put then in the same location as the 08's which is right below the Speed-Set panel.
Long story short....I had one piss all over me at the boat show when a guy sat down and hit the switch with his knee. I was standing right at the drain port
Do any of you know how to do the winterization?
I payed $230 to winterize my boat this year, I know it got to be something simple as to remove water from the system.
Anyone know a procedure on how to do it correctly?
Thanks
The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
anhaney
Thanks
there is a bunch of threads on that go through this thread and read it then click on all the links CHP provided to other threads.
http://www.tigeowners.com/forum/show...=winterization
Thanks
Can some of the fat sack be hidden behind the side panels to save storage space?
One all the gear, tube, surfboard, wakeboards, skis, life jackets, etc are in the boat I would like to keep the space I have for storage.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by eksilva View PostCan some of the fat sack be hidden behind the side panels to save storage space?
You could go with a set of 20V hard tanks.
May be able to install the factory RZ/Ve transom hard tanks, but would need to measure the height between the floor and the transom storage bins. This would also require the moving of the batts and TAPS motor to the storage lockers and building an enclosure.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostYou could go with a thinner/longer sac that would extend up under the seats and then build a removable false floor over top.
If Only I was that handy.
I guess I need to wait for anhaney and you to finish your boats.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
After we build the ballast system in my boat I'm going to try and design/build a movable shelf for when then the sacs are full and empty so I can still utilize the storage space with out worrying about tearing the sacks.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
I bet your dealer can get some carpet from the factory to cover the false floor. I think the the hard tanks (only about 8" high) or the long/narrow sacs would be the best way to go rather then the factory hard tanks. It's doable and a lot of work, but I did see one attempt go south on an 07 22Ve.
Factory was using 2 diff depth storage bins in early 07 (deeper on boats ordered w/out ballast) and the hard tanks where about 1" too tall to fit.
Lot of work involved in moving batteries, TAPS motors, building boxes, etcMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Perhaps I should just stay with the fat sacks. I might be able to handle the installation of a fat sack.
Are you helping to put the hard tanks on G-Money's boat, or is he going to install only fat sacks?The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by eksilva View PostPerhaps I should just stay with the fat sacks. I might be able to handle the installation of a fat sack.
This would give you the equivalent (maybe a little more weight) of factory ballast, but would still need to toss another sac in to get a good surf wake.
I wish I could get out there to help, but I'm on the right coatsthey are on the wrong, uh i mean, left coast.
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by G-MONEY View PostAfter we build the ballast system in my boat I'm going to try and design/build a movable shelf for when then the sacs are full and empty so I can still utilize the storage space with out worrying about tearing the sacks.
The fly high sacs are hard to tear unless you push a sharp bolt into them. I doubt that you would ever have a problem with them except for the sharp bolts underneath the seats.Be excellent to one another.
