Convex Hull Partially correct, but what was the modification?
Pop Quiz
Originally posted by billspin View PostConvex Hull Partially correct, but what was the modification?
Tige added rocker to the hull instead of hook. Page 22 of Boating Industry magazine (Oct 05 with Charlie Pigeon and the new 22Ve on the cover) states that the TAPS was introduced in 95 and TAPS 2 and the Convex V hull were released in 03.
http://tige.com/2007/downloads/Boati...ustry_Tige.pdfMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
DING...DING...DING...That is what I was looking for chpthril. OK The quiz is now yours!
Here is the quote I got this from on this site:
03-21-2005, 02:38 PM
Andrew
Moderator Join Date: Dec 2003
In 1995, Tigé made a dramatic move by taking the hook out of the inboard hull. It was the first dramatic modification to the inboard hull in over 50 years. Tigé also introduced TAPS to control the running attitude of its variable hull in '95. Tigé has since refined this improvement in inboard hull design by developing the ConvexV, fully rocker hull in 2003. Tigé received a U.S. Patent on the ConvexV hull in 2004.
Hope this helps.
Andrew
Jason B was half correct so he should post a question also.
????? *EDITED*
What was unique about Tige's 1998 yr model (built in 97) DD, the 2200i, that was a first in the Tow Boat industry.Last edited by chpthril; 10-22-2007, 06:10 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by TeamAllen View PostIn 1997 it was not called the 2200i. It was called the 2150. It was changed in 1998 to 2200i.
You are probably referring to the 102" wide beam?
Oh yeah, your correct about the increased beam, but Tige.com says 100" so you are correct as far as i'm concernedLast edited by chpthril; 10-22-2007, 06:28 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostJason B was half correct so he should post a question also.
????? *EDITED*
What was unique about Tige's 1998 yr model (built in 97) DD, the 2200i, that was a first in the Tow Boat industry.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
????? *EDITED*
What was unique about Tige's 1998 yr model (built in 97) DD, the 2200i, that was a first in the Tow Boat industry.Common Sense is not so Common
????? *EDITED*
What was unique about Tige's 1998 yr model (built in 97) DD, the 2200i, that was a first in the Tow Boat industry.Originally posted by TeamAllen View PostIn 1997 it was not called the 2200i. It was called the 2150. It was changed in 1998 to 2200i.
You are probably referring to the 102" wide beam?Originally posted by dogbert View PostIt had a V hull.Originally posted by zad0030 View PostFirst built specifically for wakeboarding
Here is what the Tige.com Tige Company Timeline says. This is where I drew my question from
1997; Tige builds the industry's first 100" beam DD inboard...the 2200i
1998; Tige launches the 21V riders ed. The first boat built specifically for wakeboarding.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Are you asking about a pickle fork or a tri-hull??Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Originally posted by Jason B View PostWhat is the 2 wire, "state-of-the-art data exchange system" that allows the engine/electrical components to communicate thousands of times per second called?
