kind of a stupied question but friend and i were out and couldnt figure out how it went and the dealer didn't know
bimini
What tower? "E" or "Z" .......Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
What type of bimini mounts do you have on your bimini? They should either be thumb screws or ball/socket ends with hooks.
I have some pictures on my home PC that I can post tonight. It took me and my dealer a while to figure out too. If you don’t know what you’re doing it will definitely confuse you.
Here are a few pictures of my RZ2 Bimini. I have the Z tower but the mounts should be similar. In the pictures the front of the bimini is loose, because I did not properly secure the front arms and supports. Once secured it looks great.
You can also look at this PDF for instructions on how to install the bimini on an E tower.
If you have any questions let me know, it is confusing at first but easy once you figure it out.
I just posted a thread a few days ago about needing info. manuals and owners info and what not. This is very helpful. This kind of stuff needs to be included in the owners manual. This is one of the very questions I have with my new 22Ve. Your pics really help. The first time we tried to install in on the day of delivery, it was like 3 monkeys ........... a football. "I'm sure you the get the idea." What a jigsaw puzzle. How about some pics of what it should look like properly stowed. I almost positive I haven't stowed my properly. Because your boat is an RZ2 and mine is the 22Ve will there be that big of a difference?
Any help would be greatly appreciated.I don't want to go to work, take me wake surfing instead!
I have a 24Ve with the manufacturer cover. It is very similiar to the setup that Matt has. The only difference that I can see is the bar holding the back of the bimini is slanted up and uprights are holding up the slanted bar. If you have the same one as me, the bar that is holding up the slanted bar is mounted to the tower and carries the bar holding the back of the bimini... Hard to explain.....
My boat is in the shop so I can't take any pictures for you..... Stupid Taps system....urgh!!!!!!!!!
Originally posted by scoot18 View PostI just posted a thread a few days ago about needing info. manuals and owners info and what not. This is very helpful. This kind of stuff needs to be included in the owners manual. This is one of the very questions I have with my new 22Ve. Your pics really help. The first time we tried to install in on the day of delivery, it was like 3 monkeys ........... a football. "I'm sure you the get the idea." What a jigsaw puzzle. How about some pics of what it should look like properly stowed. I almost positive I haven't stowed my properly. Because your boat is an RZ2 and mine is the 22Ve will there be that big of a difference?
I will post some more pictures of it stowed tonight. It should be similar to the E tower.
Attached are a few more pictures of the RZ2 tower with the thumbscrew mounts in case anyone on here comes across this thread that has this style bimini.
Matt; that looks nothing like the way I have mine stowed. Man I must really have it screwed up. I will take some shots this evening to show you what I have done and put them on this thread. I will then try to restow it like you show in your pic. May need some more wisdom and guidance on this one.
Thanks for the info so far!I don't want to go to work, take me wake surfing instead!
Originally posted by scoot18 View PostMatt; that looks nothing like the way I have mine stowed. Man I must really have it screwed up. I will take some shots this evening to show you what I have done and put them on this thread. I will then try to restow it like you show in your pic. May need some more wisdom and guidance on this one.
You have a slighly different style to your bimini. That back part of Matt's RZ2's bimini is different than ours. Now, it also depends upon the tower type also.
