Originally posted by Timmy!
View Post
RZX - one place for all rumors
Originally posted by dj2 View PostMight have a winter project.... 2 Lenco trim tabs, 2008 RZ4 and a full fab shop at my disposal. Definitely not as cool or functional as this but my family / friends are split between both sides of the boat and I would like to see if I can just weigh the boat down and switch for different riders in a few seconds instead of 5-8 minutes....Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by RZRCO23 View PostI was thinking this exact same thing...
Originally posted by chpthril View PostMastercraft's Gen-1 was basically a trim tab setup and results were lackluster. I think a surf system is going to need much further articulation then an actual trim tab system offers. Look at the Supra and MB surf system for now and hopefully we will get some shots of the TAPS-3 system in its deployed state. I think we are going to see the plate reaching farther then the TAPS plate and what any normal trim plate will.
On the Taps3 Z3 I tested you select left or right on the TT just that simple. When surfing left hit right and it instantly moves. You will feel the boat shift a bit and bam your wave is extremely clean instantly on the other side. The raptor 400 doesn't bog down at all and there is no change in speed rpm etc. The regular side wave has just as much height as my 15 without AVX and a ton if not more push. The goofy side which we only played around a bit wasn't as tall but had a ton of push and I've never seen a wave so clean! That is with just 2 adults in the boat. I would love to see this thing loaded down!
They have changed back to the 2249 prop or at least the model I was on, for this year due to several of us on here asking for a little more top end. I didn't notice a difference in hole shot compared to my 15 with the 2419 much larger prop.
A non listed boat appeals to me a whole lot more after riding behind it. We like the fast change idea and still have a great quality surf wave. This way the kids aren't screaming in between rider changes!
Tigé Junkie
- May 2013
- 920
- Central MN
Originally posted by Ewok View PostSo they are using the raptor 400 as the base model on this boat? That's a big boat for that engine, good to know it can handle it."I think I am pretty smart for an idiot"
