Hello all. Proud new z3 owner. Anyway I have a 2012 z3 with only 80 hrs on it and about every 20 minutes or so it will pump water out the rear aft starboard hole. It will pump out for about 5 min and quit. Then 20 minutes or so later kick on again.. I've opened the hatch and can't really see any water any where..is the normal?? Any suggestions would be greatly appreciated.
z3 taking on water....any ideas? normal??
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Then not engine hoses or heater hoses or anything directly related to the engine (or it would happen much faster when the engine is on). Leaky drain plug? Leaky swim platform mounts?
Since it's likely structural: Park the boat on the trailer and fill the bilge with a garden hose. If it leaks up, it will also leak down.
Probably the shaft seal, but could also be a cracked pump housing. Your boat has a dripless packing. So minus you bringing water in on swimmers/ riders you should have a 100% dry boat. The shafts don't drip to lubricate like the old days. If your bilge pump runs AT ALL you have a problem. If you didn't put water in the boat its not normal for it to be there.
One more place to look, the mufflers. Recently had the same issue on a 24ve and it was bad and about the same rate. They ended up replacing the mufflers with straight hose and some adapters. Hit the search button for "cracked mufflers" and read the threads.Fixing everyone elses boat just so I can use mine...
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by boatwakes View PostThey ended up replacing the mufflers with straight hose and some adapters.
Originally posted by JohnnieMo View PostWoah.... There is a recall on every 2013????
