Does anyone else have issues with their surf rope rubbing on the bimini top? We have the sunbrella surf Bimini on our Rzr. I have tried the rope above and below and still am trying to figure out a solution for it rubbing. It is destroying my surf ropes and also damaging the top.
Wakesurfing with Bimini top
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Yes, our rope rubs when wakesurfing if we loop it on the central tow point. Two solutions:
1) Put some heat shrink tubing on the rope in the area where it rubs on the bimini. Heat shrink is smooth and eliminates the problem. We ran like that for several years until we switched to...
2) Loop the tow rope through the "handhold" opening in the Alpha Z tower on the side you're wakesurfing. Takes all of five seconds, eliminates the rub, and gives a straighter pull in the bargain. Also costs zero time and zero dollars.
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Pass the towpoint end of the rope through the tower opening, pass the handle end through the loop in the towpoint end (like making a slipknot), and pull the slack through. Fast, free, and easily switched side to side. Hope it helps!
Tigé Junkie
- May 2013
- 920
- Central MN
Originally posted by WABoating View Post
2) Loop the tow rope through the "handhold" opening in the Alpha Z tower on the side you're wakesurfing. Takes all of five seconds, eliminates the rub, and gives a straighter pull in the bargain. Also costs zero time and zero dollars."I think I am pretty smart for an idiot"
My R20 rubs as well. This season I angled the back of the bimini down a few degrees. To early to tell if it is effective but I think it will. I have one friend who is a bit larger and when he would get up you would hear it pull down on the bimini occasionally. So far this season when he hasn't gotten up I don't hear it. Not sure if it is possible on the RZR if you don't have the Alpha Z tower, I have the Vector tower.
I saw this issue yesterday with D&P Powells Bimini. The rear bars for the Bimini that stick out from the tower come straight out. Mine slope downward so the tow point is the highest point on the Bimini. It seems to me that if you could put a little bend into those tubes to get a little downward slope it would prevent the rope from rubbing on the Bimini. I really don't know why Tige changed the angles of the Bimini but mine does not rub for wakesurfing or wakeboarding.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Originally posted by WABoating View PostPass the towpoint end of the rope through the tower opening, pass the handle end through the loop in the towpoint end (like making a slipknot), and pull the slack through. Fast, free, and easily switched side to side. Hope it helps!
