Originally posted by ragboy
View Post
No Tige Surf 'System'
My perfect pass speedo is calibrated. I run a lot of weight and I need the speed for length. I get a similar wave size and shaped wave at like 11.2-11.5 with 600-800 lbs less on surf side. That is actually what I do for newbies. It just doen't have the push and airs and such aren't as fun or big. I don't really ollie as much as just come off the lip.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
@duncan I understand the list issue, when we go back to the 24Ve or RZ2 after the Z3, it is not something I want to go back to. It is SO nice having little to no list. Our list is very minimal.
I have estimated, with all of the experience of people that I surf with, that if it switched in under 5 mins, most people would be fine with that. But yes, the list part, especially for certain wives, and mine is one of them, is an issue.http://wake9.com/
Originally posted by duffymahoney View PostMy perfect pass speedo is calibrated. I run a lot of weight and I need the speed for length. I get a similar wave size and shaped wave at like 11.2-11.5 with 600-800 lbs less on surf side. That is actually what I do for newbies. It just doen't have the push and airs and such aren't as fun or big. I don't really ollie as much as just come off the lip.http://wake9.com/
Originally posted by ragboy View Post@duncan I understand the list issue, when we go back to the 24Ve or RZ2 after the Z3, it is not something I want to go back to. It is SO nice having little to no list. Our list is very minimal.
I was NOT overly impressed with G23 general handling. Our 409 RZ2 (unlisted with or without ballast) handles sooooo much nicer than the 450 G23. But comparing an high powered, re-propped 22 foot to a stock 23 foot is probably not fair.
I really want to make it to the Polar Bear this year to surf a tweaked Z3 wave, ideally along with a G23!
Originally posted by jmoore15 View PostWhy why why why does Tige continue to send boats out in this day and age without crossover pumps and vent\drain line not crossed?? Ragboy, I agree that with your setup it minimizes the switching issue but that is not the way these boats come. Ridiculous for a new boat competing with surf system boats. Rant over.
As far as the cross vent and draining, I cannot answer, but I do know there is some reluctance due to consumer confusion. I can share with you a recent conversation in our boat as we drive in, and this is not a one time thing.
me to kid: Are we still draining out the goofy side?
kid: You mean the goofy bag, or the goofy side of the boat?
me: Is the water still still draining from the starboard side?
kid: Which one is starboard again?
dad: Where is your mother so I can smack her for giving birth to you? ( <-- joke of course )
Someone needs to engineer a solution where water comes out the same side. I was thinking maybe have the hoses go partway and back. It works fine for us the way it is, but I can see it can be confusing for new people.http://wake9.com/
Robert, did you makes holes in the rear bulkheads for the hoses/fittings for your xlink pumps to pass through (assuming they are connected to the bottom rear port of your bags). Where did you connect the other two xlink pumps, as I thought the Wake9 custom sacs only had one rear port?2013 Z3 - Electric blue and black
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by ragboy View PostSomeone needs to engineer a solution where water comes out the same side.
Tigé Junkie
- May 2013
- 920
- Central MN
ragboy - if you are looking at electronic ball valves go to:
http://www.banjocorp.com/
If you find something that you want, shoot me a PM. We purchase from Banjo as an OEM - we use some of their products in our systems. I would be happy to hook you up with a deal on some stuff from them if you find something interesting.
You can also check out:
http://www.teejet.com/english/home/p...manifolds.aspx
We are set up through them as well.
Maybe we can help you design an improved aftermarket upgrade system.
PM me if you find anything of interest. We work with several suppliers of spraying equipment and controls (valves, hoses, fittings....)"I think I am pretty smart for an idiot"
Originally posted by WABoating View PostThis is not difficult, mine has been that way since Day One. Put them forward, and they will always be above the sacs on that side. And the driver can see what is draining without even turning his head!
Where do you vent?
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by Duncan View PostIf I could turn back time, this is how I would route drains. Where do you vent?
